Bixby Irritating Problem
(Topic created on: 05-07-2024 09:03 PM)
Aadi_16
Bixby
Whenever I trigger my Bixby with power button it always shows this irritating message I have kept up with this too long, now i need a permanent fix for this developer or whatever fix this
Here's a screenshot of it
Also note it happen every single time I trigger it with power button
6 Comments
oldy01
Bixby
Ah .. this remind me of Cortana. She also used to say the same thing.
Aadi_16
Bixby
Hope Bixby doesn't go and follow that path like Cortana
oldy01
Bixby
Haha..we can only hope btw, why don't you use GAssistant , I feel it's more refined then Bixby, although Bixby routines is best they got on android that's for sure .
Aadi_16
Bixby
I use Gemini it's an a dedicated assistant so sometimes it's problematic, but it also works as assistant, it's just that I don't want to switch to hold to power off menu on power button so let the Samsung developers do some work and fix this thing or else if they can make power button be more customisable like toggle torch
oldy01
Bixby
Ah yes Gemini is still in early stage I don't want to compromise on screen search which is use often.
BTW you can customize the power button I have set it to torch for double press
oldy01
Bixby
After long pressing power button I get this and I can customize this way .1715143788644.jpg1715143788698.jpg1715143788706.jpg
