TeeA
10-14-2025 06:28 PM (Last edited 10-15-2025 09:03 AM ) in
with Galaxy
I could be impulsive on posting this but I'm doing it anyway. Everytime I updated from a major software update, I'd never experienced the battery drain that comes as a side effect, until now. After updating to One UI 8, I experienced the battery drain.
Now 'technically' the battery is supposed to recalibrate for a week or two before you see it go back to your idea of normal drain but for some that does not seem to be the case.
THE FIX:
- Yesterday, I let my phone drain completely
- Charged it to full while still off
- Went into Recovery Mode to clear system cache
- After the phone restart, I cleared the RAM(never done that before after clearing cache)
EDIT: How to get into Recovery Mode
Note that you first need to connect your phone to a computer or connect wired usb c earphones into the phone otherwise it won't work. Maybe connecting the phone to a TV may work as well, maybe.
- Press volume up + power button at the same time and not let go until the blue menu pops up.
- Use volume down to navigate to clear system cache, then use power button to select it and confirm
- Then you can reboot the phone
5 Comments
Plasmious
10-15-2025 08:12 AM in
with Galaxy
The 3rd Point how did you do it?
TeeA
10-15-2025 08:51 AM in
with Galaxy
While the phone is off you press volume up + power button at the same time and not let go until you see a menu pop up. Then you use volume down to navigate to clear system cache and the power button to confirm, then you restart(reboot) the phone.
Note that you'll have to connect your phone to a computer or connect the wired usb c headphones to the phone for this step. I'll update the post to include this step.
Plasmious
10-15-2025 12:24 PM in
with Galaxy
Thank you
Tumelo159
10-15-2025 08:14 AM in
with Galaxy
Thank you for the post💪🙏 May it hopefully help people those are experiencing the same battery drain issue.
TeeA
with Galaxy
I hope so too, that thing is annoying.
