gear IconX 2018
(Topic created on: 07-06-2019 05:06 AM)
ahtAhmadTaha
Wearables
where I can find the cleaning tools for the IconX 2018 in Doha - Qatar
7 Comments
kei22
Wearables
you mean Q tips?
ahtAhmadTaha
Wearables
no the Mish or Mesh Idk how to pronounce it but it's the black piece in the airbuds
kei22
Wearables
mesh but you can only clean with Qtips maybe bit of alcohol, that's what I normally do.
ahtAhmadTaha
Wearables
but sometimes It's won't stuck :(
kei22
Wearables
is it dirty or damaged? cause I don't know if there is replacement parts maybe try Amazon
ahtAhmadTaha
Wearables
dirty
and sometimes when I clean it it just won't stuck again :( I just have to put a new one
kei22
Wearables
the buds? rubber piece? i guess that's normal, since they aren't glued they ment to be replaced, if it's not worth it just buy different brand?
