04-25-2020 06:21 PM in
WearablesThe first thing we must do is activate wireless charging
In order to enjoy wireless charging we need to activate it and this is a process that we can do very easily on our mobile. We will have to go to the Settings, enter the section of «Device care»
In this section we find several options that allow us, depending on our model, to activate or deactivate Samsung wireless charging. We can also make other configurations such as choosing the type of load we want to do, that is, using the traditional wireless charging or opt for the fast wireless charging.
How to limit reverse wireless charging on Samsung Galaxy
In some models such as the Samsung Galaxy Note 10 or the new Samsung Galaxy S20 In all available versions, we find reversible wireless charging, an option that we must limit it so we don't run out of battery on our mobile. This will allow us to automatically disconnect the mobile and stop sharing our energy with any other device.
First of all we must activate it and we can do this in the panel of shortcuts on the button called PowerShare. To enter its advanced options and configure it we have to enter Settings> Device care> Battery and enter PowerShare Charging. Within this section we will be able to adjust the minimum battery level with which we can share our battery, establishing between 30% and 90%.
Use the original wireless charger
Although wireless charging is compatible with other charger models, wireless charging is not fast wireless charging that we are for example in the Samsung Galaxy S20 Pro. To get the most out of our mobile and that it is not affected by an incorrect charge we must always opt for the original. This charging method is more complicated than the classic cable can be, and we must opt for maximum optimization for each model.
Tips for not having problems with fast charging
Wireless charging has many advantages and is very comfortable, although we must also bear in mind that we must be more careful with everything that we leave nearby, for example we should not leave coins, metal objects, magnets or cards of magnetic stripe near the charger or we could cause a heating of the charger and problems arising later in our mobile.
Do not use the charger wet or in wet areas
Like we do not have to charge our mobile while it is wet despite having IP68 resistanceWe don't have to do it with wireless charging. Wet areas should also be limited, as we could find ourselves with charging failures and this could end up affecting the result that our mobile phone gives us.
Be careful with the covers you use
Among all the covers that are available for Samsung mobiles, not all are valid and compatible with wireless charging. Matter both the material and the thickness of the cover, what you could do not charge correctly and only achieve it by sections, affect the battery of the mobile. In this case, it is best to choose an original cover or remove the cover with each load.
Source: movilzona.es
