Watch 6 Classic Battery Drain Fix
(Topic created on: 04-29-2026 11:33 AM)
TMan296
Wearables
Hi Members,
I’m using the Galaxy Watch 6 Classic and recently I’ve noticed the battery draining way faster than before. It used to last comfortably through the day (and sometimes more), but now it barely makes it or drops very quickly even with normal usage.
Was anyone else facing the same issue?
I tried wiping out the cache of the watch and it seemed to help. 💙
8 Comments
Wearables
Yes , that helps.
Have you tried using AOD Vs not using AOD? How much difference does it make ?
Wearables
I don't use AOD that much. So can't say for now 🙈
Wearables
Ok, I will try with my watch 4.
Wearables
Let us know how it is
Wearables
Sure , I just need to do test properly and remember.😂
Wearables
We believe in you 💙🤣
Samsung_specialist
Wearables
Thank you for your participation in the Samsung Community and for sharing your experience regarding battery drain on the Galaxy Watch6 Classic.
Regarding the increased battery consumption, please note that this may occur due to certain settings, background applications, or after software updates. We recommend following the steps below to help improve battery performance:
  1. Restart the watch to close temporary background processes.
  2. Ensure the watch software is updated via Galaxy Wearable > Watch settings > Watch software update.
  3. Reduce or disable Always On Display if enabled.
  4. Turn off GPS and Wi-Fi when not in use.
  5. Check background running apps through battery settings in the Galaxy Wearable app.
  6. Enable Power Saving Mode when needed.
  7. If the issue persists, perform a factory reset after backing up your data.
If the battery drain continues after performing the above steps, you may visit the nearest authorized service center for inspection:
https://www.samsung.com/ae/support/service-center/
For further assistance, you may also refer to:
https://www.samsung.com/ae/support/contact/
Wearables
Thank you for your support 💙
