Samsung’s AKG N400 wireless earphones feature ANC, water resistance
(Topic created on: 04-06-2020 07:44 AM)
CrazyBoy28
Wearables
It was long rumored that the Galaxy Buds+ would feature ANC to compete with Apple’s AirPods Pro, but they didn’t. Now, Samsung’s AKG sub-brand has released new true wireless earphones that bring active noise cancellation. On top of that, they also offer water resistance, something that the Galaxy Buds+ are lacking.
The AKG N400 first made a surprise appearance in South Korea, but they have now been officially announced. They cost KRW 230,000 (around $190) in South Korea, which is 30% higher than the price tag of the Galaxy Buds+, but they also bring additional features. They use 8.2mm drivers that have a frequency response of 10Hz-20KHz, an impedance of 16 ohms, and a sensitivity of 96 dB SPL.
AKG N400 feature ANC, wireless charging, companion app
They use a Bluetooth 5.0 chipset, which supports SBC and AAC codecs. The new true wireless earbuds come with a bunch of ear tips, including Comply foam tips. The active noise cancellation feature is excellent for blocking out ambient noise. The level of noise cancellation can be controlled using the Ambient Aware feature, and you can use the TalkThru feature to know what’s going around you.
There are two microphones on each earbud, and AKG has implemented beamforming technology for better audio quality during voice calls. The AKG N400 TWS earphones have capacitive touch controls on each earbud for music playback and volume controls. You can even summon AI voice assistants such as Bixby, Google Assistant, and Siri on paired smartphones.
AKG N400 Earbuds Colors
Each earbud weighs 7.7g, and the case weighs 65g. The earbuds feature an IPX7 rating for water resistance, which means they can very well sustain sweating while you’re working out. The earbuds last 6 hours on a single charge (5 hours with ANC turned on), and the case can charge the earbuds once one, taking the total battery life to 12 hours. A companion app helps in customizing audio, ANC level, and touch controls.
9 Comments
Dineshbsnl
Wearables
when it's available in India..
Wearables
Soon
Dineshbsnl
Wearables
which one is better buds+ or akg n400..
i have to purchase
Wearables
For now Buds+
Dineshbsnl
Wearables
for mainly Call purposes which one is better.. i can wait for a month..
Wearables
Definitely Bud+
Dineshbsnl
Wearables
but there are noise cancelation in akg n400..
Wearables
Then Wait For AKG N400 Launch will Compare both
cs_member9
Wearables
Dear Samsung Member,
Thank you so much for showing your interest in Samsung products.We would like to share the offer details regarding Galaxy Buds+ wearable.
Some specification of Galaxy Buds+ are:
  1. Up to a huge 11hrs* of non-stop music on a single charge
  2. Rich, natural sound by AKG with powerful bass & crisp high notes
  3. Dedicated 3 mic set up for loud & clear calls in any surrounding
Kindly visit the ink for the detail regarding deal on buds+ : https://www.samsung.com/in/offer/online/samsung-fest/?deal=acc.
