Remote connection calling not working
(Topic created on: 04-02-2023 02:11 PM)
ngops
Wearables
Hi
Can someone assist with the remote connection calling, its bot working and idicated as unkown instead of showing my numbers. Already tried and the restart and resetting the watch.
Regards
2 Comments
MohammedAbbas
Wearables
Are you on Vodacom
If you are
You will need to contact Vodacom to activate your Caller ID
It will cost you an additional amount of R9.88 a month on your contract
This should fix the issue
ngops
Wearables
Thank you for the reply Mohammed. I am using a dual sim phone both sims on contract one for data another for voice. Telkom and MTN respectively
