Poor battery
(Topic created on: 02-06-2025 07:59 PM)
Swikhedzakhedzani
Wearables
My smartwatch has poor battery life. It only lasts if I use battery saver; otherwise, it does not last for eight hours.
The Galaxy Ultra has good picture quality. Look at the scratches on my watch.
13 Comments
Wearables
Clean your camera lens, also check your watch settings, from always on display time out, vibration features and the likes. If you have vibration on, kindly turn it off
Wearables
Thank you I will do so. Should I also turn off the watch Bluetooth?
Wearables
If you do that you, have it synced to your phone. That's if you just want to wear it and have it track your health, that will also save battery for sure
Munatsi399
Wearables
How will you connect it to your device without Bluetooth 🤷 ♂️
B0nga
Wearables
Switch off AOD. 😊
Wearables
I have switched it off 🙏
M2NGWA
Wearables
How old is your watch?
that watch face is not going to give you good battery life
Wearables
Almost a year old, which face should I use?
Jacques88
Wearables
After the latest update, I just used these skins. The battery lasts 2 days max. Blood pressure is off as it expired, but the others are all monitoring.20250207_133923_1000125098_1738928365.jpg
