Poor Bluetooth connection πŸ˜”πŸ˜”πŸ˜”
(Topic created on: 11-17-2019 09:05 PM)
Muba09
Wearables
My Galaxy Bud has poor Bluetooth connection, I don't understand its have bluetooth 5.0. 2 meter Far from my phone music/ call will be drop. What can I do guys
11 Comments
Rajparbat
Beginner Level 4
Wearables
full discharge it then charge and see what happens then
Muba09
Wearables
thanks bro I will try itπŸ‘πŸ‘
Sushantnayak
Wearables
The issue is with the ear buds get them replaced from service center as i was also facing the same issue and after replacement it works perfectly fineπŸ‘
Muba09
Wearables
thanks broπŸ‘,. warranty is remaining using more than 6month
Muba09
Wearables
is it possible to replacement ?
Sushantnayak
Wearables
Yes absolutely, just carry your bill and earbuds with case πŸ‘
ipradeepsah
Wearables
.update the firmware
Muba09
Wearables
I don't know about the firmware update bro
ipradeepsah
Wearables
.connect ur buds with galaxy wearable app /and then check the setting
