Official Ultra Analog Watch Face Installation Guide (No PC Computer Required)
(Topic created on: 07-31-2024 09:21 PM)
TheRishi13
Wearables
Watch Face can be installed on any galaxy watch 4,5,6
First you will need to download the source file APK for the new Ultra Analog watch face (Original) by Samsung Electronics.
Here are some trusted links...
2) Next we will contnue the Installation of the APK onto your watch & for this step we will not be using GeminiMan to complete the process. Instead please open the Play Store & search for 'ADB Shell'' a link is provided below.
3) Our next step is to locate the path to our source file APK & to rename it in a shorter format. So go ahead & open your native 'My Files' application & look under your 'Download' category. At the top of this list wIll be our Ultra Analog APK file containing several numbers, hyphens & brackets etc. None of these are actually required in the file name, so we will long press on the file & select the option to rename it.
For the purpose of these instructions please go ahead & rename the file to 'UltraAnalog.apk) or in fact whatever name you'd like.
4) Next we will prepare our watch for the next steps in the installation process. Please go into the settings on your watch & choose 'Connections', then proceed to Turn OFF Bluetooth. I will assume you already have or know how to enable 'Developer Options' on your watch, so we will continue.
Open Developer Options & look for 'ADB Debugging' & make sure this is switched ON, next look further down for 'Wireless Debugging' & again make sure this switch is also turned ON. Wait for a brief moment & tap onto 'Wireless Debugging' to bring up its submenu.
5) Next please open 'ADB Shell' app which we downloaded from the Play Store. Please also ensure you have your watch in the 'Developer Options' Wireless Debugging submenu. From here please select to pair a new device. Make a note of your IP Address (192.168.1.---) followed by a 5 digit port number at the end of your IP & a 5 digit pairing code.
In the ADB Shell app input your IP Address & Port Number then press 'Pair' button ensuring Pairing code toggle is switched ON.
Once pairing has been successful we will continue on to the next step.
6) Please take a note of your IP Address along with your newly assigned port number & select the 'Local Shell' option in the menu on ADB app & input the following command... adb connect 192.168.1.---:----- which is your IP Address followed by your 5 digit port number. Press the Return key to action the command.
At this stage if you've followed all steps in this guide correctly the Shell will return a message saying Already connected to 192.168.1.--- & if this is the case for you then we can move onto the final step of the installation process.
7) Enter the following command into the Shell on the ADB app...
adb install -i PrePackageInstaller /storage/emulated/0/Download/UltraAnalog.apk
Or whatever the path to your source file is & then press the Return key to enter the command.
😎 After a brief pause you should hopefully see a message which states a Streamlined Install was Successful.
9) Please go back into settings on your Watch & turn Bluetooth back ON.
At this point your newly installed 'Ultra Analogue' watch face should appear under 'Downloaded' section in the Wearables app & our installation process is successful.
Now please proceed to go into Developer Options again & deactivate ADB Debugging & Wireless Debugging toggles we turned on earlier.
Next please continue to customise your new watch face & choose all your complications safe in the knowledge they will all work following this step by step guide. 👍🏻❤️
8 Comments
Octopus_64bit
Wearables
Does it have night mode
TheRishi13
Wearables
Yes
Octopus_64bit
Wearables
Thanks 💯
TheRishi13
Wearables
Simple ultra night mode works automatically in low light if auto brightness is on
Kilaruness
Wearables
This doesn't work on the Galaxy Watch 7 on Wear OS 6. Anyway you can make this work on Galaxy Watch 7?
TheRishi13
Wearables
Maybe u didn't followed the steps properly and idk about wear os 6 that it works or not
Wearables
Can u make an video on it
Thisisarda
Beginner Level 3
Wearables
Cant use on my watch 6 classic with oneui watch 6 wear os 5 any fix?
