03-21-2021 10:55 AM in
Wearables- Mark as New
03-22-2021 04:47 PM in
WearablesKindly you may need to reset your Galaxy buds as below:
-Make sure that your Galaxy Buds is fully charged. Be sure to charge it using the charging case for at least 10 minutes.
-On your phone, open the Galaxy Wearable app.
-Scroll down and tap About earbuds.
-Tap Reset earbuds.
-Tap Reset to confirm.
Moreover, you may try to reset your network settings to its factory default settings. From Home screen, tap Settings > General management > Reset > Reset network settings.
Note: This will erase all network settings, including those for: Wi-Fi, Mobile data and Bluetooth.
In addition, try to clear the Bluetooth cache and data, From Home screen, tap Settings > Apps > Tap options (three dots in the upper-right corner) > Show system apps > Bluetooth > Storage > Clear Cache/Data.
Also, you can kindly try to do the below steps to solve your issue:
-Settings
-Apps
-from the top right menu choose Show system apps
-Samsung Wearable
-Storage
-Clear cache & Clear data
If the issue still exists, kindly visit Samsung service center
03-23-2021 10:56 PM in
03-24-2021 07:52 AM in
03-28-2021 09:46 AM in
WearablesHi there,
Please bring the device to a Samsung Service Center to have the device checked out.
Find the nearest service center to you online!
03-22-2021 07:17 PM in
WearablesAn update is available for buds. Give it a try and check whether it solved the issue.
03-22-2021 07:38 PM in
WearablesLet me Check after resetting to the buds as suggested by Samsung manager and see the outcome.
