Wearables
Samsung introduced its Galaxy Buds Pro at its Galaxy Unpacked 2021 event. Now it has started pre-orders for the headset in India for Rs. 15990 across Samsung’s Exclusive Stores and retail stores and on Samsung.com and leading online portals, and it will go on sale from January 29th. Customers pre-booking Galaxy Buds Pro in India will get a Wireless Powerbank U1200 for INR 499 (priced at INR 3699) during the pre-book period.
Fonearena
The Galaxy Buds Pro comes in Black, Silver and Violet colours, feature a dynamic, balanced sound coming from a 2 way speaker system (with a 11mm woofer), intelligent ANC capabilities, and lets you automatically toggle your earbuds connection between your Galaxy smartphones and tablets based on your usage – no manual adjustments required.
The Galaxy Buds Pro are protected with an IPX7 water resistance rating. With the SmartThings Find you can easily locate either of your earbuds, even when they’re out of Bluetooth range or completely out of sight, misplaced at a distant location.
Samsung Galaxy Buds Pro specifications
  • Driver unit: 2-way (11mm woofer + 6.5mm tweeter)
  • Microphones: 3 mics (2 outer + 1 inner) + Voice Pickup Unit + Wind Shield
  • Active Noise Cancellation (ANC)
  • ANC: Cutting external background noise by up to 99%, 2 adjustable levels
  • Ambient Sound: Amplifying up to + 20dB, 4 adjustable levels Voice Detect
  • Bixby Voice Wakeup
  • Connectivity: Bluetooth 5.0
  • Supported Codecs: AAC, SBC, Scalable (Samsung proprietary)
  • Sensors: Accelerometer, Gyro, Proximity, Hall, Touch, Voice Pickup Unit (VPU)
  • Compatibility: Android 7.0 or higher with more than 1.5GB of RAM
  • IPX7 water resistance
  • Dimensions: Earbuds: 19.5 x 20.5 x 20.8mm; Weight: 6.3g
    • Charging case: 50 x 50.2 x 27.8mm; Weight: 44.9g
  • Battery: Earbuds – 61mAh; Charging Case – 472mAh
  • Play Time: 5 hours (buds) / 18 hours (case) with ANC ON, 8 hours (buds) / 28 hours (case) with ANC OFF; Qi Wireless Charging, Fast charging: 1 hour of play time with 5 minutes of charging
- Vatsan
TimonN
Wearables
Price is more , if anyone doesn't want free wireless powerbank then?
It should have been 12-13k without any offer.
