04-07-2024 01:33 PM in
Wearables- Mark as New
04-07-2024 02:14 PM in
04-08-2024 06:45 AM in
04-17-2024 06:11 PM in
WearablesRestart the earbuds. Put the buds back in the case and close the lid. Wait for the light on the case to go out, about 7 seconds, and then try to connect the earbuds again.
Charge the earbuds for at least 30 minutes, and Insert the earbuds into the case and close the lid until the LED light goes out. If the indicator light flashes red or orange, charge the earbuds and case.
Reset the Wearable app. Open Settings on your phone, and then tap Apps. Locate and then tap Galaxy Wearable. Tap Storage and then tap Clear data. Tap OK on the popup.
Also check for new updates using Wearable app.
