Earbuds pro 2
(Topic created on: 09-27-2023 09:29 PM)
klanykof
Wearables
Hi
I notice that my earbuds life is below 12 hrs out of charging box
Using only 4 the calls during duty (no music or game's)
It's ok .....
2 Comments
bb91_S23ULTRA
Wearables
Hi,
It's good battery life you are getting!
Greetings.
Samsung_specialist
Wearables
Kindly note that the earbuds life depends on your usage. However, you may try to reset the buds from the Samsung wearable app > about earbuds > reset buds. Otherwise, you should check them in one of the authorized service centers.
