Buds3 pro, Mic not working and low volume isses
(Topic created on: 02-04-2025 06:05 AM)
theshaiksaleem
Wearables
I have buds 3 pro device, my first samsung prodcut which is giving nightmares for me. Suddenly it starts mic not working, after some time suddenly both buuds became low volume. That time i again need to redtsrt mobile abd. Buds to work.devices both with latest software update, if any solution about this product pls help me.
6 Comments
MdTajammul
Wearables
For the mic not working on your Galaxy Buds 3 Pro, try these quick steps:
Reconnect: Forget and re-pair the buds with your phone via Bluetooth settings.
Reset the Buds: Hold both touchpads on the buds for 10 seconds until the light blinks red.
Update: Ensure both your phone and earbuds have the latest software via the Samsung Galaxy Wearable app.
Check Mic: Clean the mic area and make sure it's not blocked.
Test on Another Device: Try using the buds with a different phone to check if the issue is with the buds or your phone.
If none of these work, consider reaching out to Samsung Support for further assistance.
Wearables
Above suggestion not working dear, i am speaking about buds3 pro. These function is not happening for this model i think.
Yasin1
Wearables
I have the same issue for buds pro 2 more than one year.... still not fixed.... disappointed with samsung support sometimes
Yasin1
Wearables
Its not buds issue.... its some phone software issue seems
Samsung_specialist
Wearables
We apology for this issue , kindly try these steps :
Clean your earbuds
Restart the earbuds
Reset your Galaxy Buds
Refer to this link : https://www.samsung.com/ae/support/mobile-devices/what-to-do-when-the-galaxy-buds-microphone-is-not-....
if the steps did not solve the issue please visit the nearest service center  https://www.samsung.com/ae/support/service-center/
Wearables
Nothing happened same issue.... and i visited service center they cleaned and returned. After some time using another day same issue started. There is something from software, it is not related to hardware i belive. Pls share log with technical team and check where the issue exactly is happening.
