Buds plus uneven battery utilisation
(Topic created on: 05-23-2020 10:37 PM)
SameerSharma
Wearables
Hi,
Right side buds plus is draining battery 6 times faster.
Left is around 90 and right is 15.
3 Comments
Khizr
Wearables
I am facing same issue. Infact right side bud is not even charging properly.
SameerSharma
Wearables
yes
ganeshk94
Wearables
Take your buds plus to the nearest Samsung service centre . They will take the buds plus and give you a DOA certificate.
2. Then scan that certificate and send it to support.estore@samsung.com.
3. After verification they will send the COUPON .
4. Redeem it from Samsung shopping app.
