08-10-2024 04:52 PM (Last edited 08-10-2024 04:53 PM ) in
Wearables- Mark as New
08-11-2024 11:40 AM in
08-14-2024 04:27 PM in
WearablesI understand how frustrating it can be when both earbuds do not charge simultaneously.
Here are a few steps to help resolve this issue:
Clean the Charging Contacts: Ensure that the charging contacts on both the earbuds and the charging case are clean and free from any debris. Use a soft, dry cloth to gently clean these areas.
Check the Charging Case: Confirm that the charging case is properly charged. Sometimes, a low charge in the case can affect the charging of the earbuds.
Reinsert the Earbuds: Place both earbuds back into the charging case, ensuring they are seated correctly and making proper contact with the charging pins.
Inspect for Damage: Check both the earbuds and the charging case for any visible signs of damage that could affect charging.
Update Firmware: Ensure that your earbuds' firmware is up to date. You can check for updates using the Samsung Galaxy Wearable app.
Reset the Earbuds: If the issue persists, try resetting the earbuds by following these steps:
Open the Galaxy Wearable app.
Go to Earbuds settings > Reset earbuds.
02-03-2025 12:32 AM in
WearablesI'm also facing the same issue. My left ear bud didn't charge frequently. I have to drop it multiple times to charge. I took this to divice center as well and I got a replacement. But the issue still persists.
08-28-2024 12:50 AM (Last edited 08-28-2024 12:54 AM ) in
3 weeks ago in
WearablesSamsung Galaxy Buds 3 Pro charging issue with one earbud
