5Ghz Mobile Hotspot doesn't work on A54
(Topic created on: a month ago)
mrug_tangy
Wearables
It seems that even though 5Ghz is chosen as the preferred band, the Mobile Hotspot still uses 2.4Ghz.
2 Comments
Grandpapª
Wearables
If you want to Hotspot other devices using 5Ghz ,the other device must have 5G network connectivity but if it doesn't support 5G, it won't be able to connect to your 5Ghz band Hotspot.
mrug_tangy
Wearables
The device that connects to my hotspot does support 5GHz Wi-Fi.
