Chandranil_797
06-17-2025 07:18 PM in
Tips
Should add volume control for two or more apps running together such as while playing game and playing music the volume of each app can be adjusted seperately using the volume control panel after pressing volume button.
PrakashDiwakar
06-17-2025 10:31 PM in
Tips
You can do with good lock module. Install good lock and check for sound assistent.
