Temporary solution to battery drain on Beta
(Topic created on: 09-30-2022 09:53 AM)
LuciferMorningstarr
Tips
Reboot in to recovery and then select the option 'Repair Apps'. Also use 4G only and disable 5g option under network connection settings.
IndiaBetaTeam
Tips
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you to please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
