Solution for battery drainage
(Topic created on: 12-11-2019 08:53 AM)
sameergupta
Tips
Since everyone is facing serious battery drainage on their phones running on Beta One UI, i suggest you all to put your phone into medium power saving. It will limit the CPU to 70% and reduce unnecessary background data connections. By doing this you can get around 2 hrs of extra battery life. I've tried this and it works well. You won't see any performance issues also. Everything will work fluid abd you'll get a better battery life.
4 Comments
rutvik149
Tips
honestly man i get easily 24 hours in a day ive no idea how these people are facing such drainage in their batteries
sameergupta
Tips
What is your usage pattern?
DrAnupam
Tips
People r facing battery drainage due to old cache file which making os buggy and glitchy. Just delete cache. For best performance do factory reset.
sameergupta
Tips
I always delete cache files after update. It didn't make any difference in battery life.
