Huge battery drain
(Topic created on: 10-11-2022 08:18 PM)
souvikghosh915
Tips
Battery optimization is worse than beta 3. Specifically Facebook, Instagram, YouTube and a couple other apps are draining battery like crazy. The phone is also getting extremely hot. So much so I can't even hold it in my hand
4 Comments
MayankP
Tips
Which phone do you use? Heating can be a problem but it depends on usage too
Tips
The heating and battery drain I'm getting is purely software optimization. I'm using S22 Plus, on Android 13 Beta 4. Beta 3 had better battery optimization overall.
Pratyušh
Tips
Hope it will get fixed with stable update🛐
IndiaBetaTeam
Tips
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report an error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
