Convert 5g to 4g in power saving mode
(Topic created on: 03-30-2025 05:40 PM)
OmkarTaras
Beginner Level 4
Tips
The feature of converting from 5g to 4g should be present in the power saving mode as it was in one ui 6 .
3 Comments
_ashu_kalyan
Tips
Yes this is useful for some of users
Samsung was not to remove this feature
Tips
Yeah I can feel you
But still you can achieve it easily through Routines.
If "Power Saving = On"
Then " Connections can be set to 4G"
OmkarTaras
Beginner Level 4
Tips
Thanks for your help 👍🏽. It didn't even occur to me 😅😂.
