Battery drain
(Topic created on: 08-13-2026 08:38 PM)
dev025
Tips
Battery drain is clearly visible after updating to One ui 9 beta. Even if the phone is not used it looses the battery faster.
2 Comments
Neelmallick
Tips
Which model are you using bro?
dev025
Tips
S26
