Battery Management of S22 Ultra
(Topic created on: 10-14-2022 08:08 PM)
MishraJiLive
Tips
Hi Team,
As I notice that Battery Drain is fast in samsung S22 Ultra although there is 4nm Processor, Please work on control of RAM and Display management.
I have a suggestion that if someone are working on such particular app for small specific time then close all previous app or you can save them into virtual memory so that it can be take less amount of RAM and then battery consuption would be low
2nd. rate the all know type of Application or game where you can decide easily how much RAM, CPU and brightness is required for smooth running so that Battery consuption also would be low.
3 Comments
-RJendra
Tips
I agree with u
MishraJiLive
Tips
Thanks
IndiaBetaTeam
Tips
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report an error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
