GalaxyA36ByDion
10-01-2026 12:32 PM in
Tips
After updating to the One Ul 9 Beta 2 build, I
am experiencing abnormal battery
consumption during both screen-on usage
and standby periods
Under moderate daily use, the battery drains
approximately 60-65% with under 4 hours of
screen-on time. Screen-off standby drain is
noticeably higher than previous builds,
consuming significant power over a 12-hour
period even with minimal background tasks.
High-drain activities (such as video
streaming and gaming) cause rapid
discharge and noticeable thermal buildup
compared to Beta 1/ stable builds
3 Comments
jaiveer0128t
a month ago (Last edited a month ago ) in
Tips
Mine also like in 1hrs itske take 15 - 20 % if I didn't do heavy work then approx 15% most of time i listen music after that its take approx 15% charge
jaiveer0128t
a month ago in
Tips
