05-15-2024 03:51 PM (Last edited 05-15-2024 03:52 PM ) in
Tech Talk- Mark as New
05-16-2024 12:50 PM in
Tech TalkDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device hangs issue: Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage
To improve the device's performance there should be sufficient space.
Kindly check the RAM in your device:
Path: Settings > Battery and Device Care > Memory.
The device's RAM should be free to improve performance. So clear the RAM once a day.
Clear app cache through Device care:
Tap on Settings>Device Care> Storage> Clean Now.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Is there any unnecessary application running in the background?
Kindly close the background running applications in the device (Tap the left side key & close the background running application).
Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications: Settings> Apps> Select the third-party application from Apps> Uninstall.
Kindly check if you are using a memory card on your device.
If you are using the memory card on your device. we will advise you to safely remove it from your device. For this follow the below steps:
Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount. Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information. Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
If you enabled Power Saving Mode, Power saving mode limits the performance of the device. So we recommend disabling the Power Saving mode in your device.
Galaxy device Camera issue: Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
