problem in S22 ultra
(Topic created on: 04-24-2022 11:59 PM)
TKSarvankar
Tech Talk
Is anyone facing problems while using power saving mode on S22 ultra...??
4 Comments
Tech Talk
Power saving reduces cpu capacity which is subjected to lagging
TKSarvankar
Tech Talk
It's S22 ultra...I mean it shouldn't be happening....it starts typing ..by itself...opening previously used app automatically
Tech Talk
No this is not expected 😕. There are some bugs
cs_member8
Tech Talk
Dear Samsung member,
Please follow the below steps, If the battery is non removable:
Press the power and volume down key simultaneously for few seconds.
Check space availability:
Is there sufficient space available in your device?
Kindly check the space on your device:
Path: Settings > Device Care >Storage
To improve the device performance there should be sufficient space. Request you to keep at least ''minimum 20% internal memory free''.
Please ensure stable Wi-Fi connection to your mobile. Downloading via mobile network may result in additional charges.
Please ensure enough storage space in your device.
Please ensure your device has sufficient battery for updating software. (above 50%)
Please follow the below steps:
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Software update.
Step3: Tap on Download and install.
Step4: Checking for software update.
Step5: Software update available.
Step6: Tap on Download.
Step7: Downloading updates.
Step8: Tap on Install now.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Warm regard,
