sumitnsinha
03-13-2020 02:27 PM in
Tech Talk
Dear users,
This is for all of you are facing problem of samsung phones slowing down and battery draining fast.
The simple reason for this is that the phone is busy performing tasks in the background. This could be because the apps areconstantly connecting to the internet and displaying notifications. Some apps work in the background consuming power and keeping processor busy.
1. Uninstall apps that you don't need on regular basis.
2. Disable notifications of apps that you don't need. There should be not more than 7-8 apps from which you do need to really get notifications.
3. Disable samsung apps that you don't need or use. Unfortunately you can't uninstall most of them.
4. Optimize the power usage setting. This will balance the performance and battery consumption.
5. Do not keep the bluetooth always on unless you have a connected device.
6. Use the device care in the setting to clear the cache and stop the apps running in the background.
7. Use the blue light filter in the display settings. This reduces the light intensity thereby reducing battery consumption and also protects the eyes. To your surprise the maximum battery consumption is by the display.
8. Do not install unknown apps as most of these generally keep themselves always connected to the parent servers through internet even without your knowledge.
9. Some samsung apps love to connect to the parent servers and collect and transfer user data at regular intervals. Disable the apps that you do not use regularly.
10. Deny apps from connecting to the internet if they not very critical to your mobile functioning.
Hope it helps. Please correct me and suggest more ways to prevent from slowing down of the phone and battery drain.
- Peace -
