camera on light sensor battery drain in m30
(Topic created on: 08-07-2020 09:02 AM)
Deep25503
Tech Talk
I am using m30 and since march i am attending zoom online lectures but the battery is draining fast and more than 15% is used by the camera on light sensor and it's been a issuenow, how to fix it? Please any good reputed member raise this question and please let us know a solution
17 Comments
Blackwinter
Tech Talk
it's not an issue it is common
Blackwinter
Tech Talk
I also face same issue in a50s
Blackwinter
Tech Talk
turn on medium power saving mode
rajkm008
Tech Talk
go to the device care app and tap the battery icon and u can see the power mode and tap the power mode and choose medium power saving this may help you the battery drainage problem
rajkm008
Tech Talk
its usually happens when you are uses apps like zoom,skype, Google class etc...its requires lot of data,camera and consumes plenty of battery as well
Deep25503
Tech Talk
ok so this is going to be an issue
rajkm008
Tech Talk
go to the camera app and u can force close the app and disable background process
rajkm008
Tech Talk
see the picture above
Deep25503
Tech Talk
ok thank you and why can't i see 720p youtube videos on my m30? i think it has 1080p resolution support? right? what about this?
