battery drain
(Topic created on: 12-01-2020 07:12 AM)
Not applicable
Tech Talk
I dont know why my galaxy losing battery per while i am sleeping while i woke up in mrng and took it is was heated last night i slept by hearing music what might be the issue???!!!
8 Comments
Anu9860
Tech Talk
remove unwanted apps and reset once if required.
arunnechlani
Tech Talk
uttammahata
Tech Talk
Before going to sleep ,
1. Turn on Wind Down
2. Turn on Don't disturb mode.
3. Clear background apps.
9114moh
Tech Talk
off bixby settings if it's on. Optimize your phone by clearing unwanted running apps
Ehsank
Tech Talk
always mention your device name
Ehsank
Tech Talk
one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Tech Talk
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Samsung_Support1
Tech Talk
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
