Hello member,
I have been facing battery drain issue from last month. When I mobile has kept on idel at night then my battery was drain up to 10 to 16 percent
Could you any one suggest me the solution to resolve issue.
I have put mobile network on 2g when I dont use at night.
5 Comments
ok decrease brightness
turn off every network at night
and lastly, use flight mode it's optional if don't want to use but it helps to reduce the battery usage overnight try this method at night
put the phone under power-saving mode at night
also mark my answer as solution as well
once factory reset ur phone
go to your settings and enable adaptive power saving option.
If the problem still persists, contact the service centre
Dear Samsung Member,
Kindly follow the below mentioned step to improve the performance of the device
  1. Perform Battery Optimization: Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
  2. Adjust screen timeout settings: Settings> Display> Screen timeout> Select minimum screen timeout.
Battery related Concern: For more information, you can also follow given link:
https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
