SINGH4
โ˜…
If youโ€™ve ever wished you could use your Microsoft Office apps as easily on your mobile device as you do on your laptop or desktop computer, youโ€™re in luck. With the new integrated Office Mobile app, Samsung and Microsoft have brought Office productivity to the Samsung Galaxy.
[ ] How to use it??
If you want to make quick changes to a particular slide, you can tap on it and a window will appear, giving you the option to edit, copy, add a comment or share.
When you tap on the A icon with the pencil, a gray toolbar will open up along with a thumbnail view of the slides in your presentation. From here, you can tap on the arrow at the right-hand corner and access the full suite of PowerPoint commands.
Among other options in the Home menu, you have the ability to add a new slide, adjust fonts and their formatting, and even change text rotation. Other menus give you additional controls โ€” just tap on Home and you will see a full list of menus with options to explore.
Insert Pictures, Audio and Video Into Your PowerPoint Presentation
If you want to add pictures, audio or video to your presentation, the process is the same. To add rich multimedia to your PowerPoint deck, simply go back to the Insert menu and select the option you want.
So this was a brief discussion on how to use power point on your Device,
By Any chance have you ever used POWER POINT ON YOUR SMARTPHONE??If yes,Let us know in the cmnt down below!!!
Courtesy:-
Karan Singh
Ashutosh Agrahari
Prabhjeet Singh
ashuhero
โ˜…
awesome๐Ÿ’ฅ
