Smart view not connected with Amazon fire Stick (Mobile screen not mirroring)
(Topic created on: 03-25-2023 12:46 PM)
rajeevrohilla
Tech Talk
I used samsung m51 which have smart view app that is not mirroring/connected to my amazon fire stick.
Any suggestions please.
cs_member8
Tech Talk
Dear Samsung member,
1: Turn off your mobile and your Smart TV for 30 seconds turn it back on and test if it fixes the issue.
2: To connect your device with a TV, follow the below steps:
Swipe down the Notification panel >> Select smart view option >> Enable Smart view >> Select the desired device >> Tap to connect TV model no. >> Notification bar will appear on the TV screen and select Allow to give permission to connect your device >> The phone is connected with the TV.
3: Both devices do not have screen mirroring switched on. You need to have the mirroring connection to be open on both your smartphone/tablet and the TV for the mirroring to work correctly.
4: If the issue still persists then kindly try the below-mentioned step to overcoming the issue-
Step 1. Enable Bluetooth and Wi-fi during connectivity.
Step 2. Settings >> Tap on Apps >> Tap on More (Three dots) >> Tap on Show system apps >> Search Smart view app >> Tap on Storage >> Tap on Clear data.
Step 3. Ensure your device and TV must be closed.
Step 4. Check Wi-Fi connectivity. Internet speed must be good.
Step 5. Go to setting >> General management >> Reset >> Setting Network Reset
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Thank you for writing to us.
Samsung Customer Support.
