02-22-2020 12:04 PM in
Tech Talk- Mark as New
02-22-2020 03:45 PM in
02-22-2020 07:52 PM in
02-25-2020 12:50 PM in
Tech TalkHi there,
Kindly follow the mentioned steps to resolve the issue in your device.
1) Check Network mode and set it to Auto Connect. (Settings > Connections> Mobile Network> Network mode> Select LTE/3G/2G auto connect).
2) Search for the Network Manually via following path (Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search).
3) Perform the reset network setting (Go to the settings>>general management>>reset>>reset network settings).
4) If still issue persists then we would suggest you to contact your service provider.
For further assistance, kindly visit the nearby Samsung service centre for the physical inspection of the device. The address details of Samsung Service Centres are available at our website. Please click on the link mentioned below to get more information:
http://www.samsung.com/in/support/servicelocation/
Regards,
Team Samsung Members
