OsmanGani
10-19-2019 03:26 PM in
Tech Talk
When i connect Charging Plug in my Salsung a 50 then Show Chek Your Charging Connection
Make Sure The Cable and Charger are properly Connected and also
Any Solution
Here Are the Screen Shot
6 Comments
sanu2k
10-19-2019 07:22 PM in
Tech Talk
your mobile is the fast charging support and the charger also
for this you have to go to settings of fast charging
check the charging system is fast or normal
if that is normal set it as fast charging
to go to that settings click on the notification
OsmanGani
10-20-2019 08:27 PM in
Tech Talk
Not Working Dear
sanu2k
10-20-2019 08:41 PM (Last edited 10-20-2019 08:41 PM ) in
Tech Talk
you have seen only charging
but I have seen the fast charging
125 KB
93 KB
sanu2k
10-20-2019 08:43 PM in
Tech Talk
make sure that charger problem
you can try any fast charger
buy any fast charger of a50
or try any fast charger of your friend
narcotix
10-21-2019 05:19 PM in
Tech Talk
charger problem for sure
sanu2k
11-18-2019 02:13 PM in
Tech Talk
are your mobile running better?
