How to keep whatsapp offline using data or WiFi??
(Topic created on: 07-30-2021 05:48 PM)
saink
Tech Talk
Is it possible that we can turn on data or WiFi and still be offline for whatsapp??
4 Comments
Tech Talk
In samsung phones,there is no official option to turn off data/wifi for specific apps,either disable whatsapp for sometime or directly reply from quick notification panel,this won't show others your online status
Or try apps like samsung max or other similar apps
VishnuAsok
Tech Talk
No options other than disabling the app.Screenshot_20210730-181438_Settings.jpg
VishnuAsok
Tech Talk
Spent some time on this and figured out below option indeed works....tried it on my S21 ultraScreenshot_20210730-184935_Device care.jpg
Š
Tech Talk
Try force stopping WhatsApp.
