How to keep a lock on Recycle bin?
(Topic created on: 10-21-2020 11:33 AM)
Thungbali
Tech Talk
As I am reluctant to keep a lockscreen because I feel safe even any strangers used my phone and I just want any of my phone user can delete a pic, message, contact, file or video by not knowing to me
I want to restore it if I feel important by double crossing their attempt.
15 Comments
Not applicable
Tech Talk
not possible......if you are using m series then directly lock app or if you use s,A,note then put that inside secure folder...... if someone deleted anything by mistake , for that only recycle ♻️ bin is there as second chance ..but there is no such way to lock it because it's default by 15 days timeline so either you lock or unlock no value
Not applicable
Tech Talk
if I solved your query then please accept my solution by clicking 3 dots on my comments 👍
Thungbali
Tech Talk
Thanks for the reply but nope as it didn't fulfill the required criteria how can I accept it as solution to my question
Not applicable
Tech Talk
how will fulfill the criteria if there is no process ...not only in Samsung there is no devices where lock is there inside recycle bin especially because no value to lock it as per theory because those are default by timeline
Tech Talk
You can't lock recycle bin..you can lock specific app by using S secure or any paid app locker..that's the only solution..snd if deleted photos goes to recycle bin..it will stay there for 15 days and you can restore those photos..
Thungbali
Tech Talk
is these any better options if possible lock gallery bin lock or contacts lock or any others if possible?
Not applicable
Tech Talk
there is no such 3rd party app which can lock bin ..... but if you sync your photo then recycle bin take 60 days time .... and for contact also there is no such method..use contact sync with Google account .
Thungbali
Tech Talk
ohk
Not applicable
Tech Talk
bro accept our solution 👍
