How to Flash Samsung Firmware using Odin | Sideload OTA Updates
(Topic created on: 08-23-2023 03:23 AM)
Sandeep_Gautam
Tech Talk
In this comprehensive guide, we will take you through an in-depth step-by-step process for installing Samsung Stock Firmware using the Odin flash tool and Sideload OTA updates on your Galaxy devices. If you’ve been pondering the idea of restoring your device to its original software state, either for enhanced stability or to address software issues, this guide is tailor-made to assist you in achieving just that.
Some users favor the inherent stability and simplicity offered by the original equipment manufacturer (OEM) software. If you find yourself wanting to revert back to the stock Samsung firmware, the process is remarkably straightforward. All you need at your disposal is your Galaxy device, a PC, a reliable USB cable, the relevant stock ROM, and, of course, the Odin flash tool.
Preparations Before Flashing
A Step-by-Step Guide for Installing Samsung Stock Firmware using Odin
  1. Extract and Prepare Firmware Files: Unzip the firmware files you previously downloaded and place them in a convenient location on your PC. These files should ideally be in either .tar or .tar.md5 format.
  2. Launching Odin and Establishing Device Connection: Execute the Odin3.exe file from the extracted folder to launch Odin. Subsequently, connect your Samsung Galaxy device to your PC while it’s in Download Mode.
  3. Choosing and Loading the Firmware Files: In Odin, meticulously click the relevant buttons (e.g., ‘AP’, ‘BL’, ‘CP’, and ‘CSC’) and load the firmware files that you previously extracted.
  4. Fine-Tuning Odin’s Configuration: Ensure that the ‘Auto Reboot’ and ‘F.Reset Time’ options are duly selected within the ‘Options’ tab of Odin.
  5. Initiating the Firmware Installation: Once all the prerequisites are met, initiate the flashing process by clicking the ‘Start’ button within Odin. The process may take some time to complete.
How to Sideload OTA Firmware Updates Using ADB on Samsung Devices
8 Comments
satzh_3223
Tech Talk
I am using S22ULTRA Taiwan mobile.. want to change csc to India please help me
Tech Talk
U can use SamFw Tool to Change CSC code
Tech Talk
Also, you Can Try this method,
  1. Type in *#06*. This should bring up the IMEI number. Copy it.
  2. Now type in *#272*IMEI# and replace IMEI accordingly.
  3. It should bring up the Preconfig page where you would find the list of all the available CSC codes.
  4. If you’re running an OXM Multi-CSC Firmware, then there could be 70+ CSC options to choose from.
  5. With that said select the desired one from the list and tap Install.
  6. Once installed, your device will reboot with the newly installed CSC as the active one.
satzh_3223
Tech Talk
Tried bro.. that code not working
satzh_3223
Tech Talk
ParthShah29
Tech Talk
is this safe for device means i not rooted my devices i want just reinstall the whole software then it will safe?
Vandanms
Tech Talk
Help! Accidentally deleted SM J701f stock firmware. Now only TWRP page appears with just 9mb of files present.
