Edge panel to control volume
(Topic created on: 04-17-2021 09:35 AM)
Not applicable
Tech Talk
I often use volume up/down , be it for calls or media. And I find not reliable on the volume keys for the long run. Would recommend to add volume control in the edge panel.
2 Comments
Tech Talk
Yes. As suggested, use One hand operation+. You can open this panel with swipe up,/down/centre or swipe-hold up/down/centre. Really neat feature.
