Battery πŸ”‹ drain (1-10%)
(Topic created on: 10-10-2024 09:07 AM)
Sammy_
Tech Talk
How many of you had faced your galaxy to drain real quick in between 1-10% ?
I feel battery retaining is real poor in this segment and it needs to be impeoved.
Any thoughts?
8 Comments
Glimpse
Tech Talk
Very well said battery draining is even faster in 1-5% phase. Definitely support with you
Sammy_
Tech Talk
True buddy
Oldy4756
Tech Talk
Battery is not that simple you think, read some articles about diffrence between battery indicator and real battery capacity available.
Sammy_
Tech Talk
I'll dig into it, but dont you think competitors outperformed samsung in this aspect ? Ok it's complicated but dont you think it has to be worked upon ?
Oldy4756
Tech Talk
What I believe is factors such as build material of device and environment play role here more then different brands if we don't t include different types of battery tech used.
So sometime same device can perform well in cool environment.
However you can be right because of optimization of software with hardware like ios etc can do wonders
Mayur000
Tech Talk
Well, in your case, the battery is riched to its final stage before die.
Sammy_
Tech Talk
Haha, not really πŸ˜‚
cs_member10
Tech Talk
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
β†’ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
β†’ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
