Battery Problem
(Topic created on: 07-18-2020 06:12 PM)
Yash4242
Tech Talk
I am getting very poor battery life on my galaxy a50
Only 3 hours of screen on time i am getting
11 Comments
ankitgawande
Tech Talk
Hey, Please check in Device manager about the consumption of battery and if any apps are running in background without any use then put them to sleep.
ankitgawande
Tech Talk
If still facing the same issue then you have do software in service center.
Not applicable
Tech Talk
Put Google app to sleep it is the most draining app. Don't worry about assistant it works. Also check which app is using high battery put them to sleep.
Yash4242
Tech Talk
ok
Tech Talk
3 hrs is too bad bro. Do u do heavy gaming?
Yash4242
Tech Talk
no heavy gaming
without gaming battery drops 1% every 5 to 7 secs
Tech Talk
Ohh common bro. thats not possible. can u tell me which app is eating ur battery.
Tech Talk
u can know that under device care in settings and go to battery
Gurjit86
Tech Talk
check which app using max Battery. after the recent update Battery issue was resolved
