BATTERY AND DEVICE OPTIMIZATION
(Topic created on: 10-16-2021 10:03 PM)
ApoorvaJK
Tech Talk
Heya folks,
Hope you all doing well. Battery and device care/optimization is needed for our device to run smoothly and effectively.
Some useful tips and tricks on it :)
Where is battery & device care/optimization?
There isn't an app icon for Battery and Device Care. But, it can be found under Settings> Device Care.
  •  Optimizing manually :)
1. Go to Device Care
2. Wait a moment while it runs a diagnosis of your device
3. Tap Optimize now
  • Auto optimization
2. Tap the options icon
3. Under options, Go to Advanced > Auto optimization
4. Tap on Time and adjust the clock when you want to optimize, then click Done
Battery :)
2. Tap Battery
3. Tap on Power Mode and select the best power saving mode for your device
Miscellaneous battery settings :)
2. Tap Battery
3. Select App Power Management
4. A number of options will be displayed. Toggle the switch next to any feature that you would like to enable or disable.
NOTE- Battery and device care is the optimization app for devices running Android 11. For Android 9 and 10, it is called Device care.
UserAdik
Tech Talk
