Galaxy S9 Battery Drain
(Topic created on: 09-22-2022 01:04 AM)
Kiyaz
Tech Expert
My galaxy s9's battery is draining so fast after 20% 😞
Any suggestions ?
13 Comments
Tech Expert
Hi,
Check this out,
https://thedroidguy.com/how-to-fix-galaxy-s9-battery-drain-issue-discharges-fast-when-it-reaches-30-...
If you found my comment useful, kindly click on the 3 dots and select "Accept Solution"
Thank you 👍.
Kiyaz
Tech Expert
I'll check
Tech Expert
Hi... S9 is now more than 4 years old. If you haven't replaced the original battery, I think now the time. How about your usual screen on time in normal usage?
Kiyaz
Tech Expert
SOT 2.5 hours 😞
Tech Expert
Then surely it's time to replace
Kiyaz
Tech Expert
I calibrated the battery, and now it's seems bit better
Nafrasmhd
Tech Expert
Whire i can get a good quality bettry. I brought one from a shop its only2000mah
Tech Expert
Hi... you can replace the battery from any of Samsung Authorized Service centres. They are replacing only the genuine parts.
Tech Expert
Time to replace your battery 🔋
