Resolved! Solved
VOLUME BUTTON PROBLEM IN S9FE
(Topic created on: 01-24-2025 01:21 PM)
AryanMehta1
Beginner Level 3
Tablets
Hi, i am facing a lot of problems with volume button of s9fe tablet. Sometimes volume buttons works and Sometimes it don't. I have searched and go through the different options in setting but it didn't worked. I have run diagnostics, at first volume up didnot worked. After doing 3 4 times finally it worked but then volume down button didn't worked. What shall i do ? This is happening since i bought this tablet. But now a days it happening more. I bought this tablet 3 months ago. What should i do ?
2 Solutions
hellopratik
Tablets
Service center to see any hardware related issue.
goodthings
Tablets
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
7 Comments
hellopratik
Tablets
goodthings
Tablets
goodthings
Tablets
Your's most welcome to here.
cs_member10
Tablets
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request that you visit our service center. Our technical team will be able to inspect your device physically and provide you with detailed information and assistance.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Tablets
0❤😊👏
Tablets
ghyty
Tablets
**bleep** samsung
