Samsung Flagships and Battery
(Topic created on: 11-15-2023 12:39 PM)
Abbyw
Suggestions
I have been user of galaxy flagships for a long time and now using the fold. Samsung being a brand that others look forward and imitate. I would like to give a suggestion Regarding the battery life and consumption. As i have used flagships like s10+, Note 10+ , S22ultra , Fold 4(*currently) i really feel samsung should work on battery optimisation and reduce the consumption as all users are different i understand but the drain of Samsung phone is high as compared to others and that is noticeable also the performance profile options that are given dosent work as described. Samsung doesn't provide fast charging as compared to standard now so battery optimisation and long battery without the fear of draining and charging twice in day should be there so users can actually feel they are using a top line phone that can last . I am writing all this as normal user . So, its a humble look into this and give us some good modes/profile or options that are useful and users can see a significant difference that yes samsung has made improvements in this department.
IndiaBetaTeam
Suggestions
Dear Samsung Member,
Thank you for sharing your feedback. We welcome your suggestion and appreciate the time and effort you have spent sharing your valuable comments.
We have noted down the feedback. We are continuously working to make our products better and more efficient.
India Beta Team
