Please improve bettery drain issue I spend 1lac for s22 ultra worst bettery life
(Topic created on: 10-19-2022 09:00 AM)
Alish17
Suggestions
😡😡😠 why so worst bettery life best I have always love samsung but please at least 8h-9h my screen on time 5h only 0-100 down all ready 5h
Please @Ceo smausng please improve bettery life please
3 Comments
Pravs10
Suggestions
Same feeling bro .After spending 1Lakh amount .I still need to roam to find out charging slot when i am outside home
pankajdpatel
Suggestions
Same hera
sihorab
Suggestions
It can be frustrating to deal with shorter battery life than expected. Have you tried adjusting your settings, like lowering the screen brightness or turning off unused apps? Also, check for software updates, as these can sometimes improve battery performance. Additionally, if you’re looking to Buy Buffable Floor Finish for your cleaning needs, you might find that certain apps or background processes could drain your battery. Hopefully, Samsung will continue working on improvements!
