Heating and network problem
(Topic created on: 09-24-2025 08:00 AM)
godar_a
Suggestions
S23 after using 15 16 min continuously started heating up with unstable network connection
Network issue remain same when we play same
Like bgmi it does not support 5G network instead of this it transfer to 4G network
Please correct this in next update
4 Comments
IndiaBetaTeam
Suggestions
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback. However, we request you to please report this feedback on the Error section, along with the logs. This would help us analyse your issue in a better way.
The path to report error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
Thank you for being our valued customer.
India Beta Team
AnasK6969
Suggestions
Same issue it automatically switches to 4g while playing BGMI even when phone is not hot
Lauki
Suggestions
Yes facing similar behavior
mcvbnm
Suggestions
Dear, how can I upgrade the S23 Ultra for the USA? I want to activate a trial version for Android 16. I currently have 15.
