Problem with Samsung dex
(Topic created on: Saturday)
ramastra
Samsung DeX
I'm using a Galaxy A16 5g phone running on one ui 8 android 16.
When I was searching for quick panel in settings, I found samsung dex in connected devices.
When I connected it to a windows 10 laptop, I only got the display with Samsung icons.
I tried to do activities on my laptop but nothing was working, I am not getting a touchpad on my phone, and my laptop's keyboard was able to perform functions on my phone.
Can anyone help me how to make Samsung dex work properly?
2 Comments
prithu2204
Samsung DeX
Due to changing dex setting in one ui 8 some features are missing or seems like buggy so wait for upcoming new update , may be samsung resolve it.
If you find this is helpful Click on the three dots of my replies right corner and accept the solution 😊
cs_member10
Samsung DeX
Dear Samsung Member,
As per your concern, we would request you to kindly follow the below given steps to use the Samsung Dex on your device.
● Connecting to an External Display Using a Cable: To use Samsung Dex, you must purchase a Dex Station, Dex Pad or HDMI adapter and connect your mobile device to an external display (TV or monitor).
● Connecting to a PC Using a Cable: You must use a USB Type-C cable to connect your smartphone to a PC.
● Connecting to a TV or PC Wirelessly.
● Officially Supported Accessories for Samsung Dex: Officially supported accessories for smartphones to use Samsung Dex through a wired connection are different from those used for tablets and foldable devices.
● Using Samsung Dex on a Tablet: You can use Samsung Dex on a tablet in one of the following three ways:
1. Use Samsung Dex directly on the tablet's touchscreen (you do not need to connect an external display).
2. Connect a monitor or TV through a cable to use Samsung Dex on a large screen.
3. Connect a TV wirelessly to use Samsung Dex on a large screen.
Open the “Notifications” panel by swiping down from the top of the tablet screen and long press the Dex icon in the “Quick settings” menu. You can search for displays available for connection and wirelessly connect a selected display.
● Wirelessly Connecting a TV or Monitor to Samsung Dex.
1. Open the quick settings menu on the mobile device and press the Dex button to turn on the feature.
2. Select “Dex on TV or monitor”.
3. Select the TV or monitor to connect from the list of available devices and press “Start now.”
4. Accept the connection request on the TV or monitor.
5. Follow the on-screen instructions to complete the connection. When completed, the Samsung Dex screen appears on the connected TV or monitor.
Please note: The performance may depend on the specifications of the TV that is used for wireless connection. We recommend using a Samsung Smart TV released in or after 2019. Wireless connection can be used with other TVs or dongles that support a phone screen mirroring/sharing feature (compatible with Miracast). Please check your TV whether it supports the screen mirroring/sharing feature. The name of the feature may differ by manufacturer. (Samsung TV – Screen Sharing/Mirroring, Sony TV – Screen Mirroring, and LG TV – Screen Share) If the surrounding wireless network is busy, it may lead to a poorer performance. Please try to connect again later. In order to connect the mobile device to a TV at 5GHz bandwidth for a smooth wireless connection, connect both the mobile device and TV to a wireless router that supports 5 GHz bandwidth and try the wireless connection. However, this may not work if the TV does not support the 5 GHz band Wi-Fi. Please check the TV specifications with the manufacturer. Maintaining a short distance between the mobile device and TV is recommended for a smooth wireless connection.
● Your PC should meet the following system requirements to run Samsung DeX:
●OS: Windows 10 (32/64 bit) above.
● CPU: Intel® Core™ i3 2.4 GHz processor or higher (Intel® Core™ i5 2.5 GHz or higher recommended).
● Qualcomm Snapdragon 8cx or higher version.
● RAM: 4GB (8GB recommended).
● Hard Disk Space: At least 500MB (recommended).
● USB: 1 free USB 2.0 port (USB 3.0 recommended).
● Screen Resolution: 1024 X 768, 32 bit or above.
● Samsung DeX may not work correctly if your device does not meet the minimum requirements.
● Connecting to a PC Wirelessly for Samsung DeX:
1. Open the notifications panel on your mobile device and drag the panel down. Next, press the DeX button to turn on the feature.
2. Select “DeX on PC”.
3. Select the PC to connect to from the list of available devices and press “Start now”.
4. Accept the connection request on the PC.
5. Follow the on-screen instructions to complete the connection. When completed, the Samsung DeX screen will appear on the connected PC.
6. The Samsung DeX must be installed on your computer. (Visit www.samsungdex.com for downloading and installing the program.) If the “Samsung DeX” icon does not appear in the system tray in the PC taskbar, run the “Samsung DeX” program. Check the Wi-Fi connection between your PC and mobile device.
Your PC and mobile device that you’re trying to connect with must share the same Wi-Fi AP (access point). For smooth wireless connection, please make sure that your PC and mobile device are connected to the same Wi-Fi AP at 5 GHz bandwidth. Wireless connection using the “Connection” feature in Windows is not supported.
