edge lightning
(Topic created on: 11-01-2020 10:11 PM)
prakharg
Questions
Can someone tell me on beta one ui 3 edge lightning option is there or not?
4 Comments
damodarsaha
Questions
temporary disabled ui 3 beta 1
AtulAutsTech
Questions
its thr..Not disable..See snapshot..Location moved to different menu.. Settings->Notification-> Brief Pop-Up Settings-> Edge LightingScreenshot_20201102-014640_Settings_23744.jpgScreenshot_20201102-014721_One UI Home.jpgScreenshot_20201102-014658_Samsung Members_23746.jpg
prakharg
Questions
thanks bro
IndiaBetaTeam
Questions
Dear Samsung Member,
Please perform the below mentioned steps to open Edge lighting settings:
Settings > Notification > brief pop up settings > Edge lighting.
Be sure to hit ♡ when you find an answer that works for you.
